trunk
sarahr202
Level 5
Level 5
hi every body!
Can any body tell me two fast ethernet ports, set to half duplex, be used for trunk?
thanks alot !
Amit Singh
Yes of course. Trunk encapsulation has nothing to do with the port duplex-settings.
But why do u want to use that. This would significantly degrade the network performance while running the trunk links which will be carrying a huge traffic across the half-duplex port.
HTH,
-amit singh
keeleym
Level 5
Level 5
Hi Sarah
AFAIK the ports have to be running in full duplex mode for a trunk to form. This is why trunks cannnot be configured on 1900 switches which only have 10mbps/half duplex ports.
Best Regards,
Michael
Amit Singh
HTH,
-amit singh
thanks amit!
