Trunking issues
lazmird
Community Member
Trunk settingTrunk setting
Hey can somebody tell me what's wrong with my trunk setting and by the way I have the same settings on switch 2 as well but the traffic is not passing between the SW1 and SW2.
Thank you in advance.
Mark Elsen
 - Better is to show running-config concerning the involved ports also check logs on both SW1 and SW2 when trunk connection is made , also issue 'show interface status gi0/1" ; check if the interface(s) is/are in trunking mode (or not).
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Mark Elsen
 M.
Thank you 🙂
only allow VLAN1 in trunk
some vlan must allow in trunk to make trunk probably.
