TrustSec on WS-C3850-24T
Morpheus80
I want do configure a switch-to-switch link security. (manual mode) on a Cisco 3850 IP-Base.
But under "sap .. mode-list" the only entry is: no-encap
I need gcm-encrypt but this option is not displayed.
SW Version: 03.06.00E
SW Image: cat3k_caa-universalk9
License Level: Ipbase
Model: WS-C3850-24T
What could be the problem?
Best Regards
The 3850 hardware is capable of MACSec, but it's not yet implemented in the software:
This is from the 3850 Q&A:
Q.    What about service modules for the Cisco Catalyst 3850?
A.     There are no service modules for the Cisco Catalyst 3850. Features supported through the service module in the 3750-X (including Flexible NetFlow and MACsec *) are natively supported by the Cisco Catalyst 3850.
* MACsec software support might be added later as part of a software update.
There is a MACsec feature on 3850 series switches but you are going to need at least 03.07.xxE IOS code. Please update IOS image and you will find gmac, gcm-encrypt and null options under sap mode-list.
