Trying to authenticate managment users via IAS Radius
Scott Fella
I'm trying to setup my switches to authenticate users via Microsoft IAS to allow for management. I have followed may links I have found on the web, but I get a failure for some reason.
IAS shows the user has been granted access but the switch shows % Authentication failed.
I have this setup on one of my switches:
aaa new-model
aaa authentication login default group radius local
aaa session-id common
radius-server host 10.52.10.4 auth-port 1812 acct-port 1813
radius-server key test
line vty 0 15
login authentication default
On the IAS remote policy I created, on the Advanced tab, I have tried to set the service-type to login and to Administrative. Also tried to add the cisco-av-pair for shell:priv-lvl=15 and tried using vedor specific, but no go.
I have looked at these links but still no go:
http://www.forum.persianadmins.com/showthread.php?p=3017
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=AAA&topicID=.ee6e1fe&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc1d598
-Scott
John Blakley
I would try to run "debug radius" and see if you can get anything from that.
HTH,
John
HTH, John *** Please rate all useful posts ***
I have used this tool extensively - Please download the test tool from this site to test the user http://www.evolynx.com/radius/dl_loadtest.aspx.
Mat
Thanks for the link.... here is the debug from the switch and I will attach the IAS settings as well.
-Scott
