TTL??
abhi-adte
I want to know what kind of problem in TTL???
please share with me...
Peter Paluch
Abhinay,
Can you be more specific? There are no problems with TTL per se The TTL is simply a number that limits the maximum number of hops a packet can travel, and, being a 1B quantity, its maximum value is 255 which is the maximum limit on the diameter of any IP network. The TTL prevents a packet from circling in a routing loop endlessly which is a good thing.
Have you heard of any problems with TTL in a particular application?
Best regards,
Peter
Peter Paluch
Abhinay,
Best regards,
Peter
