Tunnel GRE with Loopback
csco11579831
Could you please tel me how i can use a loop back with a tunnel GRE ?
Thanks you.
John Blakley
Are you wanting to use it as source/destination for the tunnel termination, or are you just wanting to advertise the loopback over the tunnel?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
hi John,
is to put in a next hop for route map,therefore, source / destination, is not it?
James,
You can apply a next-hop to a tunnel interface. For example if you have 2 ends of a tunnel:
192.168.1.1 - side A
192.168.1.2 - side B
Your route-map on side A can set a next-hop to 192.168.1.2 to force traffic over the tunnel if needed....
HTH,
John
That is doesn't working,i wat just how set up a lookback whith a tunnel GRE plz,
