03-09-2010 04:26 AM - edited 03-06-2019 10:03 AM
Hello
1)what's the stack cable that connect two 3560-E togather via 10 gig?can u give me the link for it?
2)can we run 10gig over copper?if so what is the module/cable for that?
03-09-2010 09:33 AM
Hello
Hello Alsayed.
You can not stack 3560s only 3750s. If you need to connect your 3560s together you can do that by using the fibe 10Gig uplink. You need an SC to SC fiber patch cord to do so
Reza
03-09-2010 01:24 PM
There is now copper 10 Gb available yet.
03-09-2010 09:03 PM
Hello
so i need to connect 2 3560-E togather as a Stack via these 2 modules X2-10GB-CX4?so what is the cable to do that?didnt found it on 3560-E datasheet
03-09-2010 09:09 PM
As Reza said, only the 3750/3750E and the 2975 support stack, particularly Stackwise technology. The 3560-E will support switch clustering.
