03-14-2017 09:32 AM - edited 03-08-2019 09:44 AM
Hello! I`ve recently converted 4507 switch chassis with dual sup configuration into the vss virtual switch node and it works as expected besides the case when i powering off the whole chassis and turn on again. After powering on the VSS 4507 node with dual sup both sups stuck in rommon state until i enter boot to one of them from console. Is it normal behavior? Is it possible boot one automatically?
Solved! Go to Solution.
03-15-2017 01:57 AM
Can you post the complete output to the command "sh version"? I want to see the config-registry value of both supervisor cards. Something tells me they're configured for 0x2100.
03-14-2017 03:12 PM
No, that's not normal.
Console into one of the line cards that went into ROMmon and reboot the entire chassis (if it's possible). Post the entire boot-up process. We want to see what caused the line card(s) to boot into ROMmon.
Check and make sure the config-registry is correct.
03-15-2017 01:32 AM
Hi! Here are the requested output below:
After power on both sups:
Verifying FPGA (P) Signature ....................... PASSED
Verifying ROMMON (P) Signature ......... PASSED
* Rom Monitor *
* Copyright (c) 2012-2014 by Cisco Systems, Inc. *
* All rights reserved. *
Rom Monitor (P) Version 15.1(1r)SG5
Compiled Thu 06-Nov-14 22:58 [RLS]
System : WS-X45-SUP8-E Slot [3] Peer [4]
Chassis : WS-C4507R*E Mod [1][2][5][6]
Revision : CPU 2.1 BOARD 4.0 FPGA 3.2978.834F
Memory : 4096 MB
Date : Wed Mar 15 00:04:33 2017
rommon 0 >
On the second the same:
* Rom Monitor *
System : WS-X45-SUP8-E Slot [4] Peer [3]
Memory : 4096 MB
Date : Wed Mar 15 00:05:17 2017
rommon 0 >
After input command boot on the first:
rommon 0 >boot
Loading image !!!!!!!!!!!!!!!!!!!!!!
Checking digital signature....
[mem:/cat4500es8-firmware]
Digitally Signed Release Software with key version A
Rommon reg: 0x00084F80
Reset2Reg: 0x0C200000
Conan controller 0x36A0076C..0x36C97585 Size: 0x00CAC5EC @
Radtrooper controller 0x36864BD0..0x36A0076A Size: 0x00661EDC @
Link: 0x00000080-0x16000000
Program Done!
[mem:/cat4500es8-base]
pci 0000:00:00.0: ignoring class b20 (doesn't match header type 01)
pci 0001:02:00.0: ignoring class b20 (doesn't match header type 01)
pci 0002:04:00.0: ignoring class b20 (doesn't match header type 01)
audit: cannot initialize inotify handle
mmc0: Got command interrupt 0x00030000 even though no command operation was in progress.
PME2: fsl_pme2_db_init: not on ctrl-plane
All packages are Digitally Signed
Starting System Services
Mar 15 00:06:47 %IOSXE-3-PLATFORM: process kernel: mmc0: Got command interrupt 0x00030000 even though no command operation was in progress.
Mar 15 00:06:47 %IOSXE-3-PLATFORM: process kernel: PME2: fsl_pme2_db_init: not on ctrl-plane
diagsk10-post version 6.1.0.0
prod: WS-X45-SUP8-E part: 73-14915-06 serial: CAT1919L2BQ
Power-on-self-test for Module 3: WS-X45-SUP8-E
CPU Subsystem Tests ...
seeprom: Pass
Traffic: L3 Loopback ...
Test Results: Pass
Traffic: L2 Loopback ...
Test Results: Pass
post done(68 secs)
Exiting to ios...
Loading gsbu64atomic as gdb64atomic
Using 13 for MTS slot
Platform Manager: acquire hwlock chassis(2)
Platform Manager: starting in VSS mode (chassis id 2)
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500es8-UNIVERSALK9NPE-M), Version 03.06.00.E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 27-Jun-14 06:38 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
Initializing as Virtual Switch ACTIVE processor
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4507R+E (P5040) processor (revision 2) with 4194304K bytes of physical memory.
Processor board ID FXS1922Q1BZ
P5040 CPU at 2.2GHz, Supervisor 8-E
Last reset from PowerUp
1 Virtual Ethernet interface
144 Gigabit Ethernet interfaces
28 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Press RETURN to get started!
*Mar 15 00:08:35.168: %C4K_IOSSYS-6-I: Module 11 (WS-X4748-RJ45-E S/N: CAT1927LBXP Hw: 1.1) is online
*Mar 15 00:12:37.329: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 12 (WS-X4712-SFP+E S/N: CAT1928LDZV Hw: 2.0) is online
*Mar 15 00:12:37.329: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 13 (WS-X45-SUP8-E S/N: CAT1919L2BQ Hw: 1.2) is online
*Mar 15 00:12:37.329: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 15 (WS-X4748-SFP-E S/N: CAT1919L0WY Hw: 1.0) is online
*Mar 15 00:12:37.329: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 16 (WS-X4748-SFP-E S/N: CAT1915L7RY Hw: 1.0) is online
*Mar 15 00:12:40.845: %SPANTREE-6-PORTDEL_ALL_VLANS: Port-channel20 deleted from all Vlans
*Mar 15 00:12:41.204: %SYS-5-CONFIG_I: Configured from memory by consoleSystem has been configured
*Mar 15 00:12:41.319: %SYS-5-RESTART: System restarted --
*Mar 15 00:12:41.404: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Mar 15 00:12:43.828: %SFF8472-5-THRESHOLD_VIOLATION: Te2/2/1: Rx power low alarm; Operating value: -24.2 dBm, Threshold value: -18.4 dBm.
*Mar 15 00:12:43.829: %SFF8472-5-THRESHOLD_VIOLATION: Te2/2/2: Rx power low alarm; Operating value: -24.5 dBm, Threshold value: -18.4 dBm.
*Mar 15 00:12:45.827: %SFF8472-5-THRESHOLD_VIOLATION: Te2/2/3: Rx power low alarm; Operating value: -24.2 dBm, Threshold value: -18.4 dBm.
*Mar 15 00:12:45.827: %SFF8472-5-THRESHOLD_VIOLATION: Te2/2/4: Rx power low alarm; Operating value: -28.2 dBm, Threshold value: -18.4 dBm.
*Mar 15 00:12:45.827: %SFF8472-5-THRESHOLD_VIOLATION: Te2/2/5: Rx power low alarm; Operating value: -25.0 dBm, Threshold value: -18.4 dBm.
*Mar 15 00:12:51.832: %SFF8472-5-THRESHOLD_VIOLATION: Te2/3/1: Rx power low alarm; Operating value: -30.0 dBm, Threshold value: -18.4 dBm.
*Mar 15 00:12:51.832: %SFF8472-5-THRESHOLD_VIOLATION: Te2/3/2: Rx power low alarm; Operating value: -24.4 dBm, Threshold value: -18.4 dBm.
*Mar 15 00:12:51.850: %SFF8472-5-THRESHOLD_VIOLATION: Te2/4/1: Rx power low alarm; Operating value: -26.1 dBm, Threshold value: -18.4 dBm.
*Mar 15 00:12:51.855: %SFF8472-5-THRESHOLD_VIOLATION: Te2/4/2: Rx power low alarm; Operating value: -24.0 dBm, Threshold value: -18.4 dBm.
*Mar 15 00:12:55.928: %SSH-5-DISABLED: SSH 1.99 has been disabled
*Mar 15 00:12:55.929: %SSH-5-ENABLED: SSH 1.99 has been enabled
Switch>
Switch>
Switch>
03-15-2017 01:57 AM
03-15-2017 04:24 AM
Yes, that`s was the issue. Thanks you very!
03-15-2017 04:29 AM
Also would like to ask, there are some configuration guides where port-channel interfaces for VSL link should be configured as mode trunk and others guides recommends to configure without trunk for example:
https://supportforums.cisco.com/document/124626/virtual-switching-system-vss-configuration-cisco-4500-series-switches
SW1(config)#int port-channel 5
SW1(config-if)#switchport
SW1(config-if)#switch virtual link 1
SW1(config-if)#no shut
SW1(config-if)#exit
and
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-4500-series-switches/118597-config-vss-00.html
4K_SW1(config)#int po10
4K_SW1(config-if)#switchport
4K_SW1(config-if)#switchport mode trunk
4K_SW1(config-if)#switch virtual link 1
4K_SW1(config-if)#exit
what is difference?
