Two default routes on a cisco 3750
huynhkhay
Is it possible to configure two default routes with the same metric on a cisco switch 3750?
In fact, I would like to make load balancing between 2 firewalls with these two routes.
Thanks you by advance for your help!
You can point your two default static routes to your next hope gateway
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip route 0.0.0.0 0.0.0.0 y.y.y.y
Bydefault the switch will add both the routes to its routing table with two gateways listed.By default L3 switches/router will do per-destination load-balancing if it has multiple routes avialable for a destination.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
HTH,Please rate if it does.
-amit singh
ankbhasi
Hi Friend,
Yes that's possible.
Ankur
Hi Ankur,
Could u plz explain how it works ?
-amit singh
Hi all,
Thanks you all for your help!
Bye.
