two group of 2960-s stacked switches connection problem
recep.sefer
I have two group of 2960 stacked switches connected by trunked (UTP) interface
stack-1                       stack-2
SW-1 -------UTP-------- SW-A
SW-2                           SW-B
SW-3                           SW-C
SW-4                           SW-D
I cannot ping stacks by their management IP?
Here is the config of stack-1
stack-1#sh switch
Switch/Stack Mac Address : c025.5cf1.0b80
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master c025.5cf1.0b80     14     1       Ready
2       Member 64e9.5055.bd00     1      1       Ready
3       Member 64e9.501d.f980     1      1       Ready
4       Member 64e9.5062.1580     1      1       Ready
stack-1#sh switch stack-ports
  Switch #    Port 1       Port 2
    1           Ok           Ok
    2           Ok           Ok
    3           Ok           Ok
    4           Ok           Ok
stack-1#sh run
switch 1 provision ws-c2960s-48lps-l
switch 2 provision ws-c2960s-48ts-l
switch 3 provision ws-c2960s-48ts-l
switch 4 provision ws-c2960s-48ts-l
spanning-tree mode pvst
interface GigabitEthernet1/0/48
description uplink_other_stack
switchport trunk allowed vlan 1,200,379,380,396-399
switchport mode trunk
interface Vlan1
no ip address
interface Vlan200
description management
ip address 10.8.15.4 255.255.0.0
Ok, try these sequence of commands from switch stack 1 ...
conf t
cluster enable
do sh cluster candidate
!!!!  Note the MAC address of stack-2
cluster member mac pass
end
rc 1
!!!! If everything is correct, you should be able to remote into stack-2.
13 Replies 13
Leo Laohoo
Can you post the output to commands of both stacks:
1.  sh interface trunk;
2.  sh int vlan 200;
stack-1#sh int trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi1/0/48    on               802.1q         trunking      1
Gi1/0/49    on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi1/0/48    1,200,379-380,396-399
Gi1/0/49    1,200,379-380,396-399
Port        Vlans allowed and active in management domain
Gi1/0/48    1,200
Gi1/0/49    1,200
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/0/48    1,200
Gi1/0/49    1,200
sack-1#sh int vlan 200
Vlan200 is up, line protocol is up
  Hardware is EtherSVI, address is c025.5cf1.0bc1 (bia c025.5cf1.0bc1)
  Description: management
  Internet address is 10.8.15.4/16
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not supported
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1000 bits/sec, 3 packets/sec
     112256 packets input, 7333704 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     961 packets output, 95330 bytes, 0 underruns
     0 output errors, 2 interface resets
Here is sh cdp neigbors
stack-1#sh cdp neighbors det
Device ID: BACKBONE
Entry address(es):
  IP address: 10.15.20.1
Platform: cisco WS-C4506-E,  Capabilities: Router Switch IGMP
Interface: GigabitEthernet1/0/49,  Port ID (outgoing port): GigabitEthernet4/1
Holdtime : 146 sec
Version :
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 15.1(2)SG, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 05-Dec-12 05:58 by prod_rel_team
advertisement version: 2
VTP Management Domain: ''
Native VLAN: 1
Duplex: full
Management address(es):
Device ID: stack-2
Entry address(es):
Platform: cisco WS-C2960S-48TS-L,  Capabilities: Switch IGMP
Interface: GigabitEthernet1/0/48,  Port ID (outgoing port): GigabitEthernet1/0/48
Holdtime : 144 sec
Version :
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 28-Jan-13 10:28 by prod_rel_team
Protocol Hello:  OUI=0x00000C, Protocol ID=0x0112; payload len=27, value=00000000FFFFFFFF010221FF00000000000064E950825200FF0000
Native VLAN: 1
Duplex: full
That's why you can't ping the 2nd stack's managmenet IP address.  You can't see it in "sh cdp n".
Provide the following commands from the 2nd stack:
1.  sh interface vlan 200;
2.  sh interface trunk
Maybe interface VLAN 200 is in "shutdown".
Are ports G1/0/48 and G1/0/49 going to the same switch?
Yes they are on same switch (stack-1)
here is teh topology
I can reach stack-1 by VLAN200 IP adress
But I cannot reach stack-2
                                       stack-1                       stack-2
Backbone------fiber-------SW-1 -------UTP-------- SW-A
                                       SW-2                           SW-B
                                       SW-3                           SW-C
                                       SW-4                           SW-D
On the stack 2, post the output to the following commands:
1.  sh interface trunk; and
2.  sh interface vlan 200
I cannot reach (telnet) stack-2
It is so far to me
I am sure stack-2 config is same as stack-1
is it possible to solve it without going to stack-2
Is VLAN 1 on both stack enabled or disabled?
Yes
Vlan 1 is enabled
here is config
interface Vlan1
no ip address
interface Vlan200
ip address ...
stack-1#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/4, Gi1/0/5, Gi1/0/6 ....
conf t
cluster enable
end
rc 1
Thank you very much
I  access switch with you help
I correct th config
and everthing works
Thank you very much for taking the time to rate our posts.
