01-26-2013 06:53 AM - editado 03-07-2019 11:19 AM
Hello Guys!
I hope you can help me here.
I`ve got two routers in my network.
Cable Modem connected to WAN port of the first router (E4200V2), LAN cable from E4200 LAN port connected to WAN port of the 2nd router WRT54GV3 ddwrt firmware (vpn).
1st subnet 192.168.1.1
255.255.255.0
192.168.1.1
2nd subnet 192.168.2.1
255.255.255.0
192.168.2.1
192.168.1.100 (2nd router IP address off of the 1st subnet)
Also I have DMZ pointing to 192.168.1.100 on my 1st router
Everything works fine, internet etc.... with the exception these subnets cant talk, cant see each other.
I looked on internet and couldn`t find a solution.... there are some but they didn`t work. I know I need to do smth with advanced routing,
I tried this below on my 1st E4200 router
Advanced Static Route
192.168.2.0
255.255.255.0
192.168.1.100
With this static route I`m able to access 1st router setup from 2nd subnet.... thats it. I can`t see computers etc...
Any help is appreciated. If you need more details please ask.
el 01-26-2013 06:57 AM
need to configure the route on the second router to 192.168.1.0
el 01-26-2013 07:01 AM
Thanks!
Should it look like
192.168.1.0
255.255.255.0
192.168.1.1?
el 01-26-2013 10:09 AM
255.255.255.0
192.168.2.1
Alain
el 01-26-2013 01:14 PM
Alan,
if I change it to 192.168.2.1 or 192.168.1.1 then I cant ping, its says
Reply from 192.168.2.1 Destination host unreachable....
If I change gateway to 192.168.1.100 (in advanced routing) or completely remove advanced routing on the second router I`m able to ping 192.168.1.X addresses.
I can even connect to my server 192.168.1.x from 192.168.2.x using Remote Desktop connection. But I dont see computers and shared drives on the network...... Also my network player which is on 192.168.2.x dont see media server on 192.168.1.x
I noticed also that I`m not able to ping 192.168.2.x addresses from 192.168.1.x .....
Alex.
el 01-26-2013 08:33 AM
yes
el 01-26-2013 09:55 AM
for some reason it didnt work. Still not able to comunicate. Tried to ping - 100% loss
Is there any other solutions available?
Thanks!
el 01-26-2013 01:48 PM
can u verify whether the default gateway is set correctly on u r systems
el 01-26-2013 02:59 PM
1st router
Router address 192.168.1.1
Subnet Class C
Gateway = IP provider default gateway 71.86.xxx.xxx
2nd router WAN IP 192.168.1.100
Router address 192.168.2.1
Subnet Class C
Gateway = 192.168.2.1???
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
