Types of IP Addressess for Router Interface
Muhammad Haseeb
I am new to IP Routing, I have a question if  I create router interface what kind of address I should assign to the router interface Public or private or both . Please help
blau grana
Level 7
Level 7
Hello Muhammad,
It does no matter, it depends on your requirements but good practise is to not mix up both types  in one domain. Private IPs are not routed in internet, so if you run BGP you have to use public IPs.
But if you run MP-BGP to support MPLS VPN in your network, you can use private addresses.
It really depends on scenario to decide if to use public or private IPs.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
