UDP Drop in 2960
Mahdi.ka
Hi ....
I have a Cisco switch 2960 24-port with 20 camera connected it
Sometimes camera images are displayed in black. (in NVR)
While the Ping connection is in place
What causes this problem?
There is a way to see the drop packets? (without using monitoring equipment)
Thank you for help and guidance
15 Replies 15
Depends what's actually happening, which is unclear as you've only provided a high level description of the issue. I.e. you have not confirmed whether stats show drops on interfaces, and if so, what those interfaces host.
Understand, due to the architecture of a 2960, there are certain situations that might only be corrected by using a "better" switch. Or, if the congestion is on an uplink, you might need one of higher capacity (e.g. 10g) or an Etherchannel uplink.
That aside, Mark's "quick fix" solution might be tried. Auto QoS makes quite a few configuration changes. The major "gotcha" might be that the auto QoS recognizes your video traffic for what it is and assigns it to a class that gets better resource allocation.
