un tagged connectivity with trunk interface
i have core switch connected to firewall
the interface in core configuration is
interface Ethernet103/1/24
description PA-VM2 -VSwitch2
switchport
switchport mode trunk
no shutdown
interface Vlan3
no ip redirects
ip address 10.153.16.9/21
description Gateway_Of_Server_Zone
no shutdown
and from fw it is untagged interface L3 with ip 10.153.16.8
is that is possible? how they communicate in the switch port is not layer 3?
should it be
interface Vlan3
no ip redirects
no shutdown
marce1000
 - On the trunk interface add switchport trunk native vlan 3
 M.
dbeattie
Does the interface need to be a trunk? You don't mention any other VLANs that are trunked to the firewall. If the firewall port is a standard L3 interface, wouldn't an access port on the switch be more appropriate?
Hope this helps,
Dave
