Unable to establish connectivity across 3 subnets, using 2 routers
Hi guys, I'm new to Packet Tracer and am having some trouble establishing connectivity across the topology I have attached to this post.
I have set up 3 subnets (100.0.0.0,110.0.0.0,120.0.0.0) all using a 255.255.255.248 subnet mask and Im only able to get connectivity via Ping across Router1 (so between the left and middle subnet).
I can connect with all nodes on the first two subnets to Router2 and all nodes in the far right subnet to Router2, but whatever I try I cannot get connectivity from a node in the right subnet to any of the other two subnets. Basically it looks like I cant put any traffic through Router2.
Is there anything you can see that Im missing?
Thanks in advance
post the zipped Packet Tracer project (.pkt) file...
