Showing results forĀ
Search instead forĀ
Did you mean:Ā
unable to Ping IP when using route redistribution
mahesh18
Level 6
Level 6
Hi Everyone,
I have below setup
R1 is running EIGRP and connected to R2 via EIGRP
R2 is Running OSPF and connected to R3 via OSPF.
R2 is doing the redistribution of eigrp to ospf and vice versa.
R1 config
interface FastEthernet1/0/1
ip address 10.1.12.1 255.255.255.0
R1# sh ip  eigrp nei
EIGRP-IPv4 Neighbors for AS(100)
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
0   10.1.12.2               Fa1/0/1           13 01:47:54  652  3912  0  14
R2 config
interface FastEthernet0/16
ip address 10.1.12.2 255.255.255.0
sh ip eigrp nei
EIGRP-IPv4:(100) neighbors for process 100
                                            (sec)         (ms)       Cnt Num
0   10.1.12.1               Fa0/16            12 01:49:44    1   200  0  36
interface FastEthernet0/19
  ip address 10.1.23.2 255.255.255.0
sh ip ospf 10  neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
10.1.23.3         1   FULL/DR         00:00:38    10.1.23.3       FastEthernet0/19
Redistribution config on R2
router ospf 10
router-id 10.1.23.2
log-adjacency-changes
redistribute eigrp 100 subnets
network 10.1.23.0 0.0.0.255 area 10
distribute-list 1 out
router eigrp 100
redistribute ospf 10 metric 100 100 100 100 100
no auto-summary
network 10.1.12.0 0.0.0.255
R3 config
  ip address 10.1.23.3 255.255.255.0
10.1.23.2         1   FULL/BDR        00:00:36    10.1.23.2       FastEthernet0/16
R1 Routing Table shows routes learned via ospf network of R1.
R1#sh ip route eigrp 100
     10.0.0.0/8 is variably subnetted, 15 subnets, 2 masks
D EX    10.1.10.1/32 [170/25628160] via 10.1.12.2, 01:17:03, FastEthernet1/0/1
D EX    10.1.11.1/32 [170/25628160] via 10.1.12.2, 01:17:03, FastEthernet1/0/1
D EX    10.1.8.1/32 [170/25628160] via 10.1.12.2, 01:17:03, FastEthernet1/0/1
D EX    10.1.9.1/32 [170/25628160] via 10.1.12.2, 01:17:03, FastEthernet1/0/1
D EX    10.1.13.1/32 [170/25628160] via 10.1.12.2, 01:17:03, FastEthernet1/0/1
D EX    10.1.7.1/32 [170/25628160] via 10.1.12.2, 01:17:03, FastEthernet1/0/1
D EX    10.1.23.0/24 [170/25628160] via 10.1.12.2, 01:17:03, FastEthernet1/0/1
i am able to ping the IP of OSPF interface of R2 but not of R3 as shown below
R1#                          ping 10.1.23.2
Sending 5, 100-byte ICMP Echos to 10.1.23.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/8 ms
R1#                          ping 10.1.23.3
Sending 5, 100-byte ICMP Echos to 10.1.23.3, timeout is 2 seconds:
Success rate is 0 percent (0/5)
R1#
Need to know even the route is in routing table why i am umable to ping the IP 10.0.23.3?
Also unable to ping the loopback IP of R3  below
R1#                          ping 10.1.10.1
Sending 5, 100-byte ICMP Echos to 10.1.10.1, timeout is 2 seconds:
Mahesh
cadet alain
you're getting the OSPF routes redistributed into EIGRP but is R3 getting the EIGRP routes redistributed into OSPF ?
Could you also get rid of your distribute-list on R2 in the OSPF process
Regards.
Alain
cadet alain
Regards.
Alain
Hi Alain,
Yes R3 was getting the filtered EIGRP routes from R1 via R2.
i removed the distribute list on R2 and ping worked fine now.
I understood now why ping was not working earlier as R1 int IP 10.1.12.1 was dropped by the distribute list.
Now i added this to ACL 1 on R2 which is used by distribute list on R2 and ping works fine now while using distribute list on R2.
Best regards
Mahesh
