Unable to ping MSFC after ACE force failover
new_networker
Simple topology
MSFC -> ACE
The above is in redundant design i.e. two 6500 chassis. MSFC has HSRP defined where all the VLANs/SVI are active only on Chassis 1. ACE is in bridged mode and the host is connected to the server lan.
When ACE is active on the primary leg, I am able to ping the SVI on MSFC from the host. However, when I failover the ACE via 'force failover group #' ping to SVI fails. The 'sh ft group brief' shows failover to be successful.
Please advise why would a ping stop working with ACE force failover.
Thanks.
drolemc
Level 6
Level 6
Please verify the following procedure to solve this issues.
1. Please disable:
- logging buffered debugging
- logging asdm debugging
2. Please execute Clear Xlate command.
3. Please verify your interface configurations
