Unable to Reach Vlan System while connecting from Cisco VPN
Hari Kumar Raja
Hi ,
I have a multiple Offices in my location , all my external users are connecting my site using Cisco Client to site VPN and accessing my 2 sites , All users are able to access my 2nd office servers which are in 10.10.0.x pool , i have a diffrent vlan in that same location with 10.10.35.x series and users are not able to access this pool servers , can any one help me on this as i am not much femilar with Routing . i am using ASA 5520 firewall .
Pls help me on this.
Hari
I noticed that there is another route on ASA which has nexthop 10.10.1.199. I didn't noticed this IP in interface list on switch. So it is another device between ASA and switch?
All other inside routes are routed via 10.10.10.36 which is IP of switch and this swit routes it to correct VLAN. But network 10.10.0.x and now 10.10.35.x are routed via 10.10.1.199.
What is this IP?
Jan
11 Replies 11
Jan Rolny
Level 3
Level 3
Hello Hari,
can you post configuration of your ASA? How ASA is connected to your LAN? Is there some switch or router behind ASA?
Maybe simple picture of your network would be also helpful.
Thanks.
Jan
Yes , i have a switch l3 cisco 3750 over the ASA , and the default was was 10.10.1.36 , which 1.x network was going through , for vpn users we have assigned 10.10.25.x and if any one connect the 25.x ip will assign to users.
Hi Hari,
can you please post output of:
ASA# sh route
ASA# sh interface ip brief
3750# sh ip route
3750# sh ip interface brief
Thanks.
Best regards,
Jan
ASA # sh route
Gateway of last resort is 125.62.194.59 to network 0.0.0.0
S    10.10.0.0 255.255.255.0 [1/0] via 10.10.1.199, inside
C    10.10.1.0 255.255.255.0 is directly connected, inside
S    10.10.2.0 255.255.255.0 [1/0] via 10.10.1.36, inside
S    10.10.3.0 255.255.255.0 [1/0] via 10.10.1.36, inside
S    10.10.4.0 255.255.255.0 [1/0] via 10.10.1.36, inside
S    10.10.5.0 255.255.255.0 [1/0] via 10.10.1.36, inside
S    10.10.6.0 255.255.255.0 [1/0] via 10.10.1.36, inside
S    10.10.7.0 255.255.255.0 [1/0] via 10.10.1.36, inside
S    10.10.8.0 255.255.255.0 [1/0] via 10.10.1.36, inside
S    10.10.9.0 255.255.255.0 [1/0] via 10.10.1.36, inside
S    10.10.25.9 255.255.255.255 [1/0] via 125.62.194.59, outside
S    10.10.25.11 255.255.255.255 [1/0] via 125.62.194.59, outside
S    10.10.25.10 255.255.255.255 [1/0] via 125.62.194.59, outside
S    10.10.25.13 255.255.255.255 [1/0] via 125.62.194.59, outside
S    10.10.25.12 255.255.255.255 [1/0] via 125.62.194.59, outside
S    10.10.25.5 255.255.255.255 [1/0] via 125.62.194.59, outside
S    125.62.194.49 255.255.255.255 [1/0] via 125.62.194.59, outside
C    125.62.194.48 255.255.255.240 is directly connected, outside
S*   0.0.0.0 0.0.0.0 [1/0] via 125.62.194.59, outside
ASA-PHOENIX# sh interface ip brief
Interface                  IP-Address      OK? Method Status                Prot
ocol
GigabitEthernet0/0         125.62.xxx.xx   YES CONFIG up                    up
GigabitEthernet0/1         10.10.1.35      YES CONFIG up                    up
GigabitEthernet0/2         unassigned      YES unset  administratively down down
GigabitEthernet0/3         unassigned      YES unset  administratively down down
Internal-Control0/0        127.0.1.1       YES unset  up                    up
Internal-Data0/0           unassigned      YES unset  up                    up
Management0/0              192.168.254.1   YES CONFIG down                  down
Cisco 3750:
sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.10.1.43 to network 0.0.0.0
     172.16.0.0/24 is subnetted, 1 subnets
S       172.16.20.0 [1/0] via 10.10.1.35
S    192.168.99.0/24 [1/0] via 10.10.1.35
     10.0.0.0/24 is subnetted, 16 subnets
S       10.10.0.0 [1/0] via 10.10.1.199
C       10.10.1.0 is directly connected, Vlan1
C       10.10.2.0 is directly connected, Vlan102
C       10.10.3.0 is directly connected, Vlan103
C       10.10.4.0 is directly connected, Vlan104
C       10.10.5.0 is directly connected, Vlan105
C       10.10.6.0 is directly connected, Vlan106
C       10.10.7.0 is directly connected, Vlan107
C       10.10.8.0 is directly connected, Vlan108
C       10.10.9.0 is directly connected, Vlan109
S       10.10.25.0 [1/0] via 10.10.1.35
S       10.10.26.0 [1/0] via 10.10.1.35
S       10.10.32.0 [1/0] via 10.10.1.199
S       10.10.33.0 [1/0] via 10.10.1.199
S       10.10.34.0 [1/0] via 10.10.1.199
S       10.10.35.0 [1/0] via 10.10.1.199
S    192.168.6.0/24 [1/0] via 10.10.1.35
S    192.168.1.0/24 [1/0] via 10.10.1.35
S*   0.0.0.0/0 [1/0] via 10.10.1.43
Cisco 3750#sh ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  10.10.1.36      YES NVRAM  up                    up
Vlan101                unassigned      YES NVRAM  up                    up
Vlan102                10.10.2.36      YES NVRAM  up                    up
Vlan103                10.10.3.36      YES NVRAM  up                    up
Vlan104                10.10.4.36      YES NVRAM  up                    up
Vlan105                10.10.5.36      YES NVRAM  up                    up
Vlan106                10.10.6.36      YES NVRAM  up                    up
Vlan107                10.10.7.36      YES NVRAM  up                    up
Vlan108                10.10.8.36      YES NVRAM  up                    up
Vlan109                10.10.9.36      YES NVRAM  up                    up
Vlan175                unassigned      YES NVRAM  up                    up
FastEthernet0          unassigned      YES NVRAM  down                  down
GigabitEthernet1/0/1   unassigned      YES unset  up                    up
GigabitEthernet1/0/2   unassigned      YES unset  up                    up
GigabitEthernet1/0/3   unassigned      YES unset  up                    up
GigabitEthernet1/0/4   unassigned      YES unset  up                    up
GigabitEthernet1/0/5   unassigned      YES unset  up                    up
GigabitEthernet1/0/6   unassigned      YES unset  up                    up
GigabitEthernet1/0/7   unassigned      YES unset  up                    up
GigabitEthernet1/0/8   unassigned      YES unset  up                    up
GigabitEthernet1/0/9   unassigned      YES unset  up                    up
GigabitEthernet1/0/10  unassigned      YES unset  up                    up
GigabitEthernet1/0/11  unassigned      YES unset  up                    up
GigabitEthernet1/0/12  unassigned      YES unset  up                    up
GigabitEthernet1/0/13  unassigned      YES unset  up                    up
GigabitEthernet1/0/14  unassigned      YES unset  up                    up
GigabitEthernet1/0/15  unassigned      YES unset  down                  down
GigabitEthernet1/0/16  unassigned      YES unset  down                  down
GigabitEthernet1/0/17  unassigned      YES unset  down                  down
GigabitEthernet1/0/18  unassigned      YES unset  up                    up
GigabitEthernet1/0/19  unassigned      YES unset  up                    up
GigabitEthernet1/0/20  unassigned      YES unset  up                    up
GigabitEthernet1/0/21  unassigned      YES unset  up                    up
GigabitEthernet1/0/22  unassigned      YES unset  up                    up
GigabitEthernet1/0/23  unassigned      YES unset  up                    up
GigabitEthernet1/0/24  unassigned      YES unset  up                    up
GigabitEthernet1/1/1   unassigned      YES unset  down                  down
GigabitEthernet1/1/2   unassigned      YES unset  down                  down
GigabitEthernet1/1/3   unassigned      YES unset  down                  down
GigabitEthernet1/1/4   unassigned      YES unset  down                  down
Te1/1/1                unassigned      YES unset  down                  down
Te1/1/2                unassigned      YES unset  down                  down
Hari
Hi Hari,
it seems that you have missing route to 10.10.35.0 network on ASA.
please add this route to ASA:
ASA# ip route iniside 10.10.35.0 255.255.255.0 10.10.1.199
Jan
Hi Jan,
i have added that route in my asa but no luck , when i connected using VPN client i am able to access 10.10.0.1 network in that remote site but not 10.10.35.1 or any 35.x hosts , please advise.
Hari
Do i need to add 25.x also , because after connecting vpn i am getting 25.x ip .
Hari
What is this IP?
Jan
10.10.1.199 is our router , which was QOS enabled for Our internal telecom as we have open pbx and we are using IP phones , we have used this router to divert the Voip traffic .
Hari
Jan , i am waiting for your inputs , please help me .
Hari
Hi Hari,
so check if your router has route to 10.10.35.x network.
So if you issue show ip route command from your router you will see if there is this network.
I am little bit confused with your topology. Is it like this?
ASA ----router----switch------LAN 10.10.x.x
Jan
