unable to set ip on L2 help!!!!!!!
avionics
i have a 2811 with 16 port switch but when i attempt to assign a ip address to fa1/0 i get the message unable to add ip on L2. Is the a reason for this?????help
Edison Ortiz
The reason is, those are Layer2 switchports.
You need to create a Vlan and associate those ports to the Vlan, for instance:
1) Create Layer 2 Vlan
Rack1SW1#vlan database
Rack1SW1(vlan)#Vlan 100
VLAN 100 added:
Rack1SW1(vlan)#exit
2) Create Layer 3 Vlan
Rack1SW1(config)#inter vlan 100
Rack1SW1(config-if)#ip add 192.168.100.1 255.255.255.0
3) Assign Vlan to the Port
Rack1SW1(config)#int f1/0
Rack1SW1(config-if)#switchport access vlan 100
HTH,
__
Edison.
thanks for the help i will see it that resolves my issue.
