understanding port channeling..
nikhil.kulkarni
Folks,
I have a picture attached to understand some concepts on port channel:
I have a Switch-A connected to Switch-B as shown. On port a I have created a port channel between port Gi0/1 and G0/2.
However, on Switch-B port Gi0/1 and Gi0/2 are left as is it, no port channel is created.
Should this not be a problem? I still see that connectivity is present ans hosts on VLAN 10 are able to communicate to each other.
What issue would this cause in the real world?
9 Replies 9
Reza Sharifi
You need to configure etherchannel on both switches, if not it can cause loop in your network
agreed..but what doubts me is I tried this in the LAB and had few machines connected, I did not observe any loops. Maybe because I just do not have enough machines connected to create the traffic.
But, why should this work in the first place?
Nik
Inspect the
show spanning-tree
show etherchannel summary
output to see the port states and which ports are used for traffic.
Switch-A:
Mutha#sh spanning-tree
VLAN0001
  Spanning tree enabled protocol ieee
  Root ID    Priority    32769
             Address     0001.C78C.8DDB
             This bridge is the root
             Hello Time  2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32769  (priority 32768 sys-id-ext 1)
             Aging Time  20
Interface        Role Sts Cost      Prio.Nbr Type
Po10             Desg FWD 3         128.27   Shr
VLAN0010
  Root ID    Priority    32778
  Bridge ID  Priority    32778  (priority 32768 sys-id-ext 10)
             Aging Time  20
Fa0/1            Desg FWD 19        128.1    P2p
Mutha#
Mutha#sh etherchann summ
Flags:  D - down        P - in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
10     Po10(SU)           PAgP   Gig0/1(P) Gig0/2(P)
Mutha#
___________________________________________________________________________________________________
Switch-B:
ICC#sh spanning-tree
VLAN0001
             Cost        4
             Port        26(GigabitEthernet0/2)
             Address     0030.F2D0.5D61
             Aging Time  20
Gi0/2            Root FWD 4         128.26   P2p
Gi0/1            Desg FWD 4         128.25   P2p
VLAN0010
             Cost        4
             Aging Time  20
ICC#
ICC#sh ether summary
        d - default port
Number of channel-groups in use: 0
Number of aggregators:           0
ICC#
Thnx,
Nik
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
You're sure your configuration hasn't formed a port-channel dynamically?
PS:
If you have a real L2 loop, it generally causes major issues in the real world.
I am sure Joseph,
I have manually configure the trunk.
Parvesh Paliwal
Level 3
Level 3
can you share the config and sho spanning-tree output ?
only then you can see if the same has faced a blocked port due to STP.
Hi Paresh,
I pasted the show spanning tree above:
here is the sh run on the ports:
Switch-A
interface Port-channel 10
description ** to ICC **
switchport mode trunk
Switch-B
interface GigabitEthernet0/1
description ** to Mutha **
interface GigabitEthernet0/2
Hi Nik,
What types of switches do you use? If they don't support EtherChannel Inconsistency Detection then the etherchannel will be formed from the one side (using mode on), thus creating a L2 loop. Sure it is a serious issue in real world - creating a L2 loop can and will have impact on throughput and CPU's of switches and hosts as broadcast storms will arise. In addition, L2 loops create mac address table incosistency.
Best regards,
Jan
