12-11-2011 09:40 AM - edited 03-07-2019 03:50 AM
Hi all,
le
I have question regarding OSPF point to point serial link cost ---
I have 2 Routers conencted back to back with T1 cross over cable.
Router 1
2650XM# sh run int se0/0
Building configuration...
Current configuration : 165 bytes
interface Serial0/0
ip address 10.20.4.1 255.255.255.0
ip ospf hello-interval 40
service-module t1 clock source internal
service-module t1 timeslots 1-24
end
2650XM#sh ip ospf int se0/0
Serial0/0 is up, line protocol is up
Internet Address 10.20.4.1/24, Area 3
Process ID 1, Router ID 1.1.1.1, Network Type POINT_TO_POINT, Cost: 65 ***************************************************
Transmit Delay is 1 sec, State POINT_TO_POINT,
Timer intervals configured, Hello 40, Dead 160, Wait 160, Retransmit 5
oob-resync timeout 160
Hello due in 00:00:17
Index 1/6, flood queue length 0
Next 0x0(0)/0x0(0)
Last flood scan length is 1, maximum is 1
Last flood scan time is 0 msec, maximum is 4 msec
Neighbor Count is 1, Adjacent neighbor count is 1
Adjacent with neighbor 5.5.5.5
Suppress hello for 0 neighbor(s)
Router 2
Internet Address 10.20.4.2/24, Area 3
Process ID 1, Router ID 5.5.5.5, Network Type POINT_TO_POINT, Cost: 64 *******************************************
Hello due in 00:00:34
Next 0x0(0)/0x0(0)
Last flood scan time is 0 msec, maximum is 0 msec
Adjacent with neighbor 1.1.1.1
2620Router# sh run int se0/0
Current configuration : 90 bytes
interface Serial0/0
ip address 10.20.4.2 255.255.255.0
end
My question is why i serial link shows cost as 64 and other as 65?
Is this normal in serial link of OSPF ?
MAhesh
Solved! Go to Solution.
12-11-2011 11:03 AM
Mahesh,
The issue was the bandwidth. According to the calculation I provided above, it should be 64.76, but as along as they are both the same then this should not be an issue. So you are good to go.....
12-11-2011 10:12 AM
It should be the same on both unless you modified the bandwidth or the reference bandwidth on R1.
Could you post sh int s0/0 as well as sh run | section ospf on R1
Regards.
Alain
12-11-2011 10:24 AM
Hi Cadet,
Thanks for reply.
Here is info from R1
2650XM#sh int serial 0/0
Hardware is PQUICC with Fractional T1 CSU/DSU
Internet address is 10.20.4.1/24
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,***************************
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:07, output hang never
Last clearing of "show interface" counters 1d03h
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1152 kilobits/sec
11687 packets input, 814409 bytes, 0 no buffer
Received 11347 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
11639 packets output, 831642 bytes, 0 underruns
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
2650XM#sh run | inc section ospf on R1
2650XM#
R2 Router
2620Router#sh int se0/0
Internet address is 10.20.4.2/24
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,*******************************************
Last input 00:00:08, output 00:00:02, output hang never
Available Bandwidth 1158 kilobits/sec
11675 packets input, 834456 bytes, 0 no buffer
Received 11377 broadcasts, 0 runts, 0 giants, 0 throttles
11721 packets output, 816733 bytes, 0 underruns
I see bandwidth is different on both links.
Is thats the cause of issue?
MAhesh
12-11-2011 10:33 AM
Mahesh,
Yes, that is the problem. can you change
service-module t1 timeslots 1-24 to
service-module t1 timeslots 1-24 speed 64
and try again?
Reza
12-11-2011 10:42 AM
Hi Reza,
I did that on R1 router and then did unplug the cable.
Still same thing as below
2650XM# sh int se0/0
Hello due in 00:00:33
Next 0x0(0)/0x0(0)
2650XM#
Next 0x0(0)/0x0(0)
2650XM#
MAhesh
12-11-2011 10:48 AM
Ok, can you add these 2 commands to r1 (dce side) and try again?
service-module t1 framing esf
service-module t1 linecode b8zs
12-11-2011 10:54 AM
Hi Reza,
I added the command ---service-module t1 timeslots 1-24 speed 64
on R2 router and now cost is 65 on both links
Process ID 1, Router ID 5.5.5.5, Network Type POINT_TO_POINT, Cost: 65
Hello due in 00:00:37
Next 0x0(0)/0x0(0)
2620Router#
So now bandwidth is same on both links.
And both shows cost of 65 is that normal?
So issue was with bandwidth difference between two links right??
Mahesh
12-11-2011 11:03 AM
Mahesh,
12-11-2011 11:16 AM
Many thanks again Reza.
Mahesh
12-11-2011 10:15 AM
Hi Mahesh,
Both sides should be 64.
cost= 10000 0000/bandwith in bps
So, in you case sine it is a full T1, we take 100,000 and divided it by 1544
100000/1544=64
Can you sh and no sh the interface on r1?
if this does not help, can you disconnect the cable and reconnect it?
Reza
