unexpected packets on port
RolandMai3
my szenario:
i have several cisco 6500 switches, and user switched connected to them.
in my example i have a global service vlan, where some access ports are directly connected on the 6500, and this vlan is also allowed on the trunks to the access switch.
now i am connected with ma laptop on a access switch, where my port is in the same vlan. when i do a show mac address-table on my access port, i can see my own mac-address, nothing else.
when i start wireshark to see the traffic, all i should see is traffic from or to my MAC, or broadcasts/multicasts.
But i can see other unicast traffic with different source/destination mac than mine.
What could be the reason for this issue?
It seem slike these packets get broadcasted over the whole VLAN, but its no broadcast MAC nor IP..
thanks in advance,
Roland
Roland,
YES the unicast flooding happens with VRRP too.
The solution is the same as HSRP.
You need to adjust the mac table time out to equal the ARP cache of 4 hours
mac-address-table aging-time 14400
See link
http://www.cisco.com/en/US/docs/solutions/Enterprise/Campus/HA_campus_DG/hacampusdg.html#wp1108782
Alex
Regards, Alex. Please rate useful posts.
acampbell
This is a problem caused on 6500s running HSRP.
You are seeing UNICAST flooding.
Look at these links.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801d0808.shtml
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00807347ab.shtml#broadcast
Basically you need to set the the 6500 mac address timout to be the same as the ARP cache on the switches that are running L3-HSRP
This will then equal 4 Hours, same as the ARP cache.
Alex
thanks for the links, but they only helped me on another problem though
at least i will now set the unicast flood protection (action = syslog) to see exactly what is happening.
actually i dont use HSRP at all, does it also apply to VRRP?
and in special conditions i can create packets myself (for example normal PINGs) which gets flooded too
thanks
Roland
Roland,
See link
Alex
thank you, helped a lot.
things getting clear now ;-)
