Unicast flooding issue with 3750g
mirko.corosu
Hi all,
Sniffing on an host interface connected to my 3750g I get many unicast packet destined to different hosts and not coming from the machine where I started the sniffing task. Doing some investigations I realized that several mac addresses was disappearing
too fast from the mac address table:
c3750G-48T-ST#show mac-address-table address 00:26:9e:3c:7e:6a
          Mac Address Table
Vlan    Mac Address       Type        Ports
   1    0026.9e3c.7e6a    DYNAMIC     Po10
Total Mac Addresses for this criterion: 1
and after between 10 and 20 seconds:
          Mac Address Table
c3750G-48T-ST#
The aging time is the default one:
c3750G-48T-ST#show mac-address-table aging-time vlan 1
Global Aging Time:  300
Vlan    Aging Time
   1     300
It does not look like a problem of spanning tree, as the topology does not change that often:
c3750G-48T-ST#show spanning-tree vlan 1 detail | include change|from
  Topology change flag not set, detected flag not set
  Number of topology changes 313 last change occurred 13:42:30 ago
          from Port-channel1
  Times:  hold 1, topology change 35, notification 2
  Timers: hello 0, topology change 0, notification 0, aging 300
Which tests can I perform to understant the causes of this issue?
Thank you
Mirko
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You may want to review: http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801d0808.shtml
Hi Joseph,
Thank you for your quick response. Non of the three cases included in the document can be applied to the issue:
- No asimmetric path, as the packets flooded are destined to hosts in the same vlan as the sender host.
- No spanning tree topology changes (at least as I can see issuing the command "show spanning-tree vlan 1 detail" as shown in the first post)
- No forwarding table overflow:
c3750G-48T-ST#show mac-address-table count vlan 1
Mac Entries for Vlan 1:
Dynamic Address Count  : 453
Static  Address Count  : 1
Total Mac Addresses    : 454
Total Mac Address Space Available: 1728
It seems that the mac addresses involved are aging-out too fast. Any ideas?
Thank you
Mirko
We need to remember that content addressable memory (CAM) is set to five
minutes, after that the mac address will be deleted if no traffic is
received from that address. The default ARP table time is four hours. This
difference of time will produce the issue.
As
ymmetric routing can isolated with:
Adjust the MAC aging time on the respective switches to 14400 seconds or
longer. This will make the time to be the same as the ARP table. Or vice
verse. Or;
Change the MAC aging time and ARP timeout to the same timeout value.
Please refer to the next links that explain much asymmetric routing and
asymmetric routing with HSRP:
<http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note091
86a00801d0808.shtml#cause1>
<http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a008
0094afd.shtml#t8>
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080
094afd.shtml#t8
For an specific VLAN you can change the aging time of the table with the:
Switch(config)#mac-address-table aging-time [time in seconds] [vlan id] or;
Switch(config)#mac address-table aging-time [time in seconds] [vlan id]
 hope this helps.
RegardsInayath
Hi Inayath,
I've configure the aging time to 14400 but unfortunately it doesn't solve the issue as it seems that several MAC addresses still disappear from CAM in less than 30 secs after the switch learnt them.
As I wrote before, asymmetric routing is not cause if the problem.
Thank you again
Mirko
