Unknown Device Password Workaround?
c.lennox
I am assuming this is a no straight off the bat, but i just inherited a network with a nexus 3000 series switch that i am able to get console to, but dont know the admin or any password. Is there a way to reset this without destroying the switches current config? I.e factory reset.
5 Replies 5
Harold Ritter
Hi @c.lennox ,
Try the following password recovery procedure.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/password_recovery/b_nx_os_pwr/nx_os_pw.html
balaji.bandi
simple steps :
https://www.balajibandi.com/?p=1392
BB
c.lennox
Hi Chaps.
Thanks for your replies. I will give these a go on Monday. However am I right in assuming that both methods require login to the console, not just console access with a login prompt? Bear in mind that i dont have ANY logins at all for this switch. Also, i am not able to reboot this switch as it is in production. Bit of a pickle i know. This is why the previous team were asked to leave.
you need to pull the power cord and do the as suggested steps
BB
c.lennox
Just thought i would come back and let you know none of the above worked. Thanks for the info though. Appreciated.
