unknown protcol drop
Hello
do any one know what does that mean in show interface fastether0/0 counter
unknown protcol drop , and why it increases
Thanks & BR
Moamen
Giuseppe Larosa
Hello Moamen,
this error counter increments when frames that are correct at OSI layer 2 carry inside a protocol type that is not known or not running on the fas0/0 interface.
Example:
IS-IS packets are not ip packets we use it for routing, access layer switches count is-is hellos as unknown because they are not running IS-IS.
There are other possible reasons : ipv6 packets or layer 2 signalling packets like VTP or STP and others
if they increment regurarly over time like 1 one every 10 seconds or some every few seconds the reason is a not understood protocol.
if the number is not great you should be fine (no issues for your router)
Hope to help
Giuseppe
Thanks fr your help, just do you have any document on Cisco support that , as our customer need such document becuse he think it is a problem .
Thanks & BR
Moamen
Hello Moamen,
unfortunately I couldn't find a clear explanation.
I tried to look at the command reference
http://www.cisco.com/en/US/docs/ios/interface/command/reference/ir_s4.html#wp1019043
However, if no real issue is seen in the network this is a so called cosmetic problem.
Hope to help
Giuseppe
eborcher
Can you provide us with the following output:
(1) show interface fastethernet 0/0 counter
(2) show interface fastethernet 0/0
(3) show version
