Unknown protocol drops between Router 3925 and routed port (6504)
a-l-e-x
Hi all,
the "Unknown protocol drops" are increasing fast at our WAN Router...
This is my setup: 3925 GigabitEthernet0/0/0 <--> 6504VSS Gig1/3/44 connected directly with a optical fibre patch (multimode LC).
3925:
interface GigabitEthernet0/0/0
 description ### lesx3350h131rz-vss Core ES1 Gi1/3/44 ###
 ip address 10.2.2.50 255.255.255.252
 ip flow monitor NetFlowMonitor input
 ip ospf message-digest-key 10 md5 samething
 ip ospf network point-to-point
 media-type sfp
 service-policy input MARKING
6504:
interface GigabitEthernet1/3/44
 description to wan-router
 no switchport
 ip address 10.2.2.49 255.255.255.252
Do you have any good ideas and notices for me?
THANKS
At the 6504 Gig1/3/44 is no error
GigabitEthernet1/3/44 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 0008.e3ff.fc28 (bia 0008.e3ff.fc28)
  Description: to wan-router
  Internet address is 10.2.2.49/30
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is SX
  input flow-control is off, output flow-control is on
  Clock mode is auto
  Last input 00:00:01, output 00:00:02, output hang never
  Last clearing of "show interface" counters 39w6d
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 341000 bits/sec, 362 packets/sec
  5 minute output rate 1607000 bits/sec, 317 packets/sec
  L2 Switched: ucast: 2255536 pkt, 163838478 bytes - mcast: 2610171 pkt, 308895417 bytes
  L3 in Switched: ucast: 4308731392 pkt, 623833862866 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 2796743155 pkt, 1387714351566 bytes mcast: 0 pkt, 0 bytes
     4314190498 packets input, 624480681276 bytes, 0 no buffer
     Received 3177186 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     2942425892 packets output, 1411302093802 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
But at our WAN Router:
GigabitEthernet0/0/0 is up, line protocol is up
  Hardware is EHWIC-1GE-SFP-CU, address is f44e.0569.0903 (bia f44e.0569.0903)
  Description: to core
  Internet address is 10.2.2.50/30
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Full Duplex, 1Gbps, media type is SX
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:12:19
  5 minute input rate 1021000 bits/sec, 276 packets/sec
  5 minute output rate 353000 bits/sec, 385 packets/sec
     192812 packets input, 87242183 bytes, 0 no buffer
     Received 207 broadcasts (0 IP multicasts)
     256367 packets output, 29468172 bytes, 0 underruns
     106 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Richard Burts
This is not an uncommon issue. It is frequently caused by some protocol on the switch side (like Dynamic Trunking Protocol) that is not recognized on the router side.
Rick
Rick
Hi Rick,
thanks for your reply, but on other side of my router is a routed-port from 6504 (VSS) with the mentioned config...
Within 3 days there are already a lot more of these drops:
     37161 unknown protocol drops
Alex
Alex
My next suggestion would be to do a packet capture on the interface of your 3925 and see if it will identify the source and type of the unknown protocol packets.
Rick
Rick
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Normally, setting a L3 switch port to "routed" disables most "special" L2 protocols that create unknown protocol drops on a "real" router port.  It's possible the L3 switch is still sending something out the port that the router port doesn't recognize, or perhaps there's something both the L3 switch and router ports would recognize but there's a configuration difference issue.  For example, I'm wondering if CDP or LLDP is enabled on the L3 switch but not the router, etc.
You many need to SPAN the L3 switch port and see what all it's transmitting.
