Unknown protocol drops
fred.gardner
Community Member
I'm receiving the following display on a 2811 fast ethernet connection and am not sure what it means:
FastEthernet0/0 is up, line protocol is up
20 unknown protocol drops
23 Replies 23
I car pool, so I can't tonight, but I will tomorrow. Thanks for your input...!
Fred
Here's the router Fa0/0:
interface FastEthernet0/0
description LAN interface at 700 E Santa Fe St Olathe
ip address 192.168.231.1 255.255.255.0 secondary
ip address 10.10.46.1 255.255.255.0 secondary
ip address 10.110.81.1 255.255.255.0
ip helper-address 192.168.48.50
ip helper-address 172.17.48.50
no ip redirects
no ip unreachables
ip directed-broadcast 143
no ip proxy-arp
no ip mroute-cache
duplex full
speed 100
no mop enabled
and the switch:
interface FastEthernet0/1
description Connection to Branch Router
duplex full
speed 100
on the switch can you issue this command
show int fa 0/1 switchport
By default, "Negotiation of Trunking" is in "ON" status. Please check the switch port to "access mode". "switch mode access".
I have not got a 2924 to test with but
I think it uses DISL rather than DTP
Yes, you could be right.
I would like to turn off any trunk negociation.
UMB208SW11#show int fa 0/1 switchport
Switchport: Enabled
Administrative mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: isl
Operational Trunking Encapsulation: isl
Negotiation of Trunking: Disabled
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: NONE
Pruning VLANs Enabled: NONE
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
Self Loopback: No
"Negotiation of Trunking: Disabled"
Well thats put a stop to that idea.
Can you put the switchport in to portfast mode.
I think you are going to need to install wireshark on a laptop and SPAN that port to look for the unknown protocol or during out of hours over a weekend look at using debug commands (ip packet detail - be carefull" on the router.
Have you got a hosts / printers on that switch with protocols like IPX DLC/LLC running?
Agree. we have to do a sniffer to find out what the packet causes the drop if you don't know what else traffic is on that link.
