Untrusted DHCP
Andy White
Level 3
Level 3
We had a user put a home router on our network as it had a hub, however the router had DHCP enabled so we started to get users phone up saying they had connectivity issues.  It took me ages to find out there was another DHCP device on the network.  Firstly how can I stop this and secondly how could I of located this issue quicker?
We use 2960s, 3560s and 3750s.
You need DHCP-Snooping:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swdhcp82.html
With that you mark your uplinks as trusted and only on these links the DHCP-Answers are allowed.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
5 Replies 5
Peter Paluch
Andy,
DHCP Snooping is your answer, definitely. Are you aware of this feature? See
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/15.0_2_se/configuration/guide/swdhcp82.html
Best regards,
Peter
I couldn't get that URL to work.
Is this VMPS that I have just noticed coudl be a solution?
just get rid of the partner subdirectory in the url and it will be functional.
No VMPS is not a solution, this is for dynamic vlan port assignment not for mitigating rogue dhcp servers.
You definitely need the DHCP snooping feature that Peter and Karsten told you about before.
Regards.
Alain
just removed the "partner" in the link ... I always forget that when posting links ...
