Upgrade 9500
RRFS578780
I'm going to upgrade the IOS, and I need what point of attention I should take before the activity.
Here are the current and new devices and versions:
C9500-16X
Current version: 16.9.3
New version: 17.03.03
C9200L-48T-4G
Current version: 16.12.04
New version: 17.03.04
I need to know if I can go straight to the new version and if there is anything to do or change before the upgrade.
Leo Laohoo
Direct upgrade, from 16.X.X, to 17.X.X is possible.
IMPORTANT:  Please read the Release Notes carefully.
Please see attached document for a summarized version of the upgrade process.
I found this, and was wondering if there's anything else to worry about upgrading.
  • Upgrading the software image from Cisco IOS XE Gibraltar 16.12.x to any of the later releases can result in a persistent database operation failure and after which the persistent database cannot be restored.
    To avoid the persistent database operation failure, use the dir bootflash:.dbpersist command to list all DB persist files and then use delete bootflash:/.dbpersist/folder_name/file_name and bootflash:/.dbpersist/folder_name/file_name.meta commands to delete individual database and meta files from each persistent database folder.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/software/release/17-3/release_notes/ol-17-3-9200.html#id_67808
That is from the 9200/9200L Release Notes.
I do not have any experience managing this platform so I cannot make any comment about this.
