Upgrade cisco Nexus 3064
Comwave Telecom
Hi Community Support
We have pair of cisco Nexus 3064 Chassis ("48x10GE + 4x40G Supervisor") running version 6.0(2)U6(5a)
Need to know the upgrade path to follow to get it upgraded to 9.3.11 per below document recommendation
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/recommended_release/b_Minimum_and_Recommended_Cisco_NX-OS_Releases_for_Cisco_Nexus_3000_Series_Switches.html
Please assist
marce1000
  - FYI : https://www.cisco.com/c/en/us/support/docs/switches/nexus-3048-switch/216023-nexus-3048-nx-os-software-upgrade-proced.html#anc46
 M.
5 Replies 5
marce1000
 M.
thank you so much Marce. That link is really helpful
So I was testing upgrade on similar model lab N3K switch which was initially on 6.0(2)U3(1).
I upgraded it successfully to intermediate version 6.0(2)U6(2a) per the link you shared
Then I tried to upgrade it to 6.0(2)U6(5a) and it seems to fail and stuck at initialization
Can you advise?.
Attached are logs from console for the upgrade attempt
Does the internal disk/flash have enough space for the new OS?
thank you for looking into it.
Yes it does . issue was USB was plugged in. I removed USB and reloaded the switch and it came up on 6.0(2)U6(5a) version
ignore, i was able to fix it.  I had forget to remove the usb. Removed the usb and then reload and it came back up with version 6.0(2)U6(5a)
