Upgrade extreme switch firmware
shallugarg6343
Hi all,
I was trying to upgrade Extreme X440-8t from summitX450-15.5.3.4.xos to summitX-16.2.4.5-patch1-3.xos
Reason of upgrade is to enable SSH on the extreme and to disable the telnet.
So, we have a FTP server and i can ping that FTP from the switch and while i run the command to upgrade, i get the below error.
GCI-WILMINGTON-EXTREME.34 # download image 1.2.3.4 summitX-16.2.4.5-patch1-3.xos vr VR-Default secondary
Do you want to install image after downloading? (y - yes, n - no, <cr> - cancel) Yes
Downloading to SwitchError: Failed to download image - tftp: timeout
Please suggest what am i missing here. Is it the low memory space on the switch or something else. Do not know how to delete the current firmware on the switch to free some memory.
file attached
Leo Laohoo
Wrong forum -- This is not the Extreme Network forum.
Mark Elsen
  - FYI : https://community.extremenetworks.com/home
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
hard to say. Do you have basic IP connectivity to the TFTP server ? Which TFTP server software are you using ?
The thread linked below has some suggestions:
https://community.extremenetworks.com/communities/community-home/digestviewer/viewthread?MessageKey=d7aa51a8-d73a-4f4f-9a4a-6430ca227f98&CommunityKey=929e6d1f-141a-4b6d-b66e-7ebfd2f3f952&tab=digestviewer#bmd7aa51a8-d73a-4f4f-9a4a-6430ca227f98
  - Adding a good place to start is to have a look at the tftp server's logs
 M.
       Beauty and terror
      Just keep going
       No feeling is final
