Upgrade firmware for EA6500
Deconight
Hi!
after unsuccessful firmware of my router, I try to flash it through UART. But putty tells me:
cfe_led_init: start to set power LED and switch LEDs.
Invalid command: "et"
Available commands:
Broadcom CFE version 1.0.37 for BCM947XX (32bit,SP,LE)
Build Date: Thu Sep  6 14:11:42 CST 2012 (lzh@team2compiler2)
Copyright (C) 2000-2008 Broadcom Corporation.
Init Arena
Init Devs.
This is a Serial Flash
Boot partition size = 524288(0x80000)
Found an ST compatible serial flash with 256 4KB blocks; total size 1MB
No NAND flash type found
The NAND flash type is (null)
bcm_robo_enable_switch: EEE is disabled
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.39.39.30
CPU type 0x19749: 600MHz
Tot mem: 131072 KBytes
CFE mem:    0x80900000 - 0x80A67900 (1472768)
Data:       0x809515D0 - 0x80954A50 (13440)
BSS:        0x80954A50 - 0x80965900 (69296)
Heap:       0x80965900 - 0x80A65900 (1048576)
Stack:      0x80A65900 - 0x80A67900 (8192)
Text:       0x80900000 - 0x809515C8 (333256)
Boot:       0x00A68000 - 0x00AA8000
Reloc:      I:00000000 - D:00000000
Boot version: v0.1.9
Device eth0:  hwaddr C8-D7-19-F8-48-A7, ipaddr 192.168.1.1, mask 255.255.255.0
        gateway not set, nameserver not set
Please use tftp to upload an image for upgrade...
cfe_led_switch_fail: loading firmware fail in boot, then blink power led.
nflash1.trx: Device not found
nflash1.trx2 CRC check failed!
nflash1.trx CRC check failed!
Both images bad!!!
CFE> cfe_led_init: start to set power LED and switch LEDs.
Available commands:
Init Arena
Init Devs.
Both images bad!!!
Available commands:
Init Arena
Init Devs.
Changed to the other image 0 (maxpartialboots exceeded)
Both images bad!!!
CFE>
0 Replies 0
