Upgrade from Cisco to Netflow
kikeabcd2
Hello Team Cisco
I want to configure Netflow on these 02 computers:
1) Switch 3750G
Hardware Board Revision Number: 0x02
Switch Ports Model SW Version SW Image
Eur-lex.europa.eu eur-lex.europa.eu
     1 24 WS-C3750G-24T 12.2 (35) SE5 C3750-IPBASE-M
* 2 24 WS-C3750G-24T 12.2 (35) SE5 C3750-IPBASE-M
If I update the IOS, can you configure Netflow?
2) Router 2911
NAME: "CISCO2911 / K9 chassis", DESCRIPTION: "CISCO2911 / K9 chassis"
PID: CISCO2911 / K9, VID: V06, SN: FTX1646AKW5
NAME: "4 Port GE Non-POE EHWIC Switch on Slot 0 SubSlot 0", DESCRIPTION: "4 Port GE Non-POE EHWIC Switch"
PID: EHWIC-4ESG, VID: V01, SN: FOC17123TTP
UDI License:
Device # PID SN
* 0 CISCO2911 / K9 FTX1646AKW5
This model supports Netflow, but for the HWIC it does not support.
If I update IOS will support or not support.
Best regards
Mark Malone
you need another module to do netflow on a 3750 and I believe its only on X series  its a hardware piece you need not software ...C3KX-SM-10G
you cant do it on standard G model as there is no module slot
http://www.solarwinds.com/documentation/en/flarehelp/netflow/content/nta-cisco-catalyst-3560-3750-sw2048.htm
