Upgrade of 6500
davidmv13
I must upgrade to “s72033-adventerprisek9_wan-mz.122-33.SXI4.bin”.  The requirement for this IOS is for Minimum Memory: DRAM:512 MB  Flash:512 MB.
I have 512MB DRAM.
Is the Flash requirement a combined flash total of the entire chassis?  I have 256MB in Disk0, 128MB in Disk1, 64MB in bootflash, and 64MB in sup-bootflash to give a total of 512MB.
Is that safe to upgrade?
Thanks!
hbruyere
This image takes 115Megs (115807.0 KB) so if you do some cleanup it should fit on your 256megs disk0.
Herve
Reza Sharifi
  I have 256MB in Disk0, 128MB in Disk1, 64MB in bootflash, and 64MB in sup-bootflash to give a total of 512MB.>
You cannot combine all these different flash cards together and make one.  You need to have 512 on your disk0 or disk1.
If you are running a modular code the size is about 146Mb, and for none-modular, it is about 116Mb.  You could give it try and loaded it in your disck0, but the recommendations as you noted is to have 512.
Reza
Reza Sharifi
BTW, load SXI4a not SXI4
