Upgrading 6500 switch VSS from NPE to regular image using eFSU
Anas Hijjawi
We are planning to upgrade our 6500 VSS switch, it is running 15.1SY1 NPE image to a newer regular image - K9 not NPE - and we need to know if this is supported or not
Thanks, Anas *--* Please rate the useful post,its free ;) *--*
Reza Sharifi
Not NPE is supported, but using eFSU to deploy it may not work. The easiest way maybe to copy and pate the new image in both switches, change the boot variable and reboot them.
