Upgrading Cisco c3650 Switch
motiar
I want to upgrade 2 Cisco c3650 Switchs with the current releases either cat3k_caa-universalk9ldpe.SPA.03.06.06.E.152-2.E6.bin or cat3k_caa-universalk9.16.03.05b.SPA.bin, I see some IOS-related files already active in Flash and they are:
"cat3k_caa-base.SPA.03.06.00E.pkg
cat3k_caa-drivers.SPA.03.06.00E.pkg
cat3k_caa-infra.SPA.03.06.00E.pkg
cat3k_caa-platform.SPA.03.06.00E.pkg
cat3k_caa-iosd-universalk9.SPA.152-2.E.pkg
cat3k_caa-wcm.SPA.10.2.102.0.pkg"
My question is whether I can delete these .pkg files before or after upgrdading with the new release.
Best regards
Motiar
Mark Malone
For cleaning files in flash on ios-xe its best to use the software clean command after you have done the upgrade it will find anything not in use
software clean
To remove any and all packages and provisioning files that are no longer in use, use the software clean command in Privileged EXEC mode.
software clean [ filefile url ] [ switchnodes ] [ verbose ]
Syntax Description
filefile url
Full path to wildcarded filename(s). Optional when running in installed mode. When no command options are specified, all unused package, bundle and provisioning files in the current boot directory will be cleaned.
switchnodes
(optional) Specifies which switch(es) should perform the clean operation using '1,2,4' and/or '2-4' notation. Default is all switches in the stack.
verbose
(optional) provides some additional info in the log files .
Command Default
No software package(s) will be cleaned by default.
Usage Guidelines
If no specific file to be deleted is indicated, the installer will search for unused packages and provisioning files on a given media device (eg., bootflash:, usb0: etc) to delete. One or more nodes may be given.
With no options specified for software clean, all unused packages and provisioning files on the currently booted device will be cleaned. The currently booted device is where the committed packages.conf file resides.
Thank you mark for your reply and detailed infrmation.
Leo Laohoo
Read the Release Notes. There are commands to delete files which are not in use by the OS.
