Uplink fast and transit node
N.ima0102
Almost in every I read document,mentioned that uplink fast sholud not be activated On transit node and must be activated only on access switch.
But I could not find out the reason.
Thanks for any guidance
Uplink fast is to aid direct link failure. whenever a switch loses its root port, and if it has an alternate port towards the root (receiveing BPDU's) then it can directly move that ATLN port into Forwarding bypassing LIS/LRN state.
When we move to those state, we dont want this switch to be a root. so we increase the priority and cost so that the switch and its corresponding links.
since we skip the LIS/LRN state, it is advisable only to be enabled at Access layer switch.
-Vijay
