Uplink Level
mohamedalthaf
I have two switch both are uplink 10GB at fiber  connection
normally my data transfer less 1GB
how to check the 10GB  bandwidth support in switch level  command  and tools
Not this any other or any tools
sh interfaces tenGigabitEthernet 2/0/1
InayathUlla Sharieff
Kindly check with the following:-
show int tenGx/x
5 minute input rate xxxx bits/sec, 124 packets/sec
5 minute output ratexxxx
sh interfaces tengig x/x summary
regards
Inayath
i need check uplink 10GB interface capability also
any dummy data transfer check any command
Thats the cmd to check at the interface level.
Else you can you any third parth software to achieve this.
