uplink Problem Catalyst 2950
blue4cisco
We hv a 2950 catalyst switch, it was running fine in the network some day ago. Now it does'nt work with uplink, whenever we connect to it another switch(D-Link) it light remains orange(uplink port, other are running fine(Green Light)) & no connectivity. please resolve it.
7 Replies 7
I assume the uplink port is a trunk port ? Can you post the output of 'show interfaces x', where 'x' is the uplink port ? Do you have any redundant uplinks (which could cause a spanning tree loop) ? Which D-Link model do you have ?
GP
desai.jaideep
Level 5
Level 5
Hi!
Pls tell me:-
1)Are you using uplink port of D-Link Switch?
2)Are you using Crossover cable to connect both the switches?
In case of (1)try using a straight cable.
In case of (2)try connecting it with port 3 of cisco and port 3 of D-link, which are not upilnk/trunk etc
Above should solve ur problem on physical layer.If that dose not help,give the 'show interface fx' output.
regards,
JD
Hi jai,
When i connect both switch with cross cable (Cisco & D-Link) they are working without web access, means D-link is connected to modem which providing 1Mbps RF from VSNL.Now if I remove I mbps cable from D-Link it ok, but i want internet access , connecting to D-link switch(with web cable)cisco switch shows ORANGE port(uplink from D-Link)& it do not connect if i remove internet cable from Dlink , cisco switch works..... What is problem thr ?
what type of modem do you have connected to the D-Link switch ?
GP
hi,
My make of modem that is connected to Dlink Switch is Packet wave-130 (Aptro Network)
can you try and change your physical setup ? From what I understand from your post, your setup looks like this:
Cisco Switch --> D-Link Switch --> PacketWave Modem
Can you try and change this to:
D-Link Switch --> Cisco Switch --> PacketWave Modem
that is, connect the Cisco switch to the PacketWave modem, and the D-Link switch to the Cisco switch ?
GP
I believe that GP is right,You should try to connect using his topology.
JD
