Uplinkfast in RSTP
alex_ciobanu
Is Uplinkfast enabled in RSTP ?
S1#show spanning-tree
VLAN0001
  Spanning tree enabled protocol rstp
S1#show spanning-tree uplinkfast
UplinkFast is enabled but inactive in rapid-pvst mode
I see it says is enabled, but inactive, but yet there are some ports in ALT state. However, if it should be enabled by default, it shouldn't modify the ports costs to high values, and also the bridge priority ?
Peter Paluch
Hi Alex,
RSTP natively contains improvements similar to UplinkFast and BackboneFast that can not be disabled. You do not need to enable anything special to already have the necessary functionality. The UplinkFast and BackboneFast will be reported as disabled in your output because RSTP uses its own implementations of the same improvements. In fact, it is not appropriate to try to enable UplinkFast and BackboneFast when running RSTP.
Best regards,
Peter
Peter Paluch
Hi Alex,
Best regards,
Peter
Reza Sharifi
In addition to what Peter noted, when uplink fast is enable the switch priority is changed.
See example
Before uplink fast is enabled
Switch(config)#do sh spann
VLAN0001
  Spanning tree enabled protocol ieee
  Root ID    Priority    32769
             Address     001b.5400.3380
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority   32769  (priority 32768 sys-id-ext 1)
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi1/0/1             Desg FWD 19        128.1    P2p
after uplink fast is enabled
Switch(config)#spann
Switch(config)#spanning-tree up
Switch(config)#spanning-tree uplinkfast
VLAN0001
  Root ID    Priority    49153
  Bridge ID  Priority    49153  (priority 49152 sys-id-ext 1)
             Aging Time  300 sec
  Uplinkfast enabled
Gi1/0/1             Desg FWD 3019      128.1    P2p
Switch(config)#
alex_ciobanu
Yes, I know, that happens in traditional mode stp, I was reffering to RSTP.
However, things are clear now, UPlinkfast does not exist in RSTP, but simmilar implementations are available by default.
