Urgent help. No connection between server and router layer 3 switch
reynosoalmonte
From server to router0 I don't have connection.
From layer 3 switch2 i can ping router.
From layer 3 switch1 i can't ping router.
here is the running config of router, sw1, sw2.
Also see the design please.
SW1:
Current configuration : 3535 bytes
! Last configuration change at 16:31:02 UTC Wed Jul 18 2018 by user01
hostname SW-PRINCIPAL
boot-start-marker
boot system flash cat4500e-entservicesk9-mz.152-2.E8.bin
boot system flash bootflash:cat4500e-entservicesk9-mz.152-2.E8.bin
boot-end-marker
interface FastEthernet1
vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface GigabitEthernet1/1
switchport trunk allowed vlan 2-4094
switchport mode trunk
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface GigabitEthernet1/5
interface GigabitEthernet1/6
interface GigabitEthernet1/7
interface GigabitEthernet1/8
interface GigabitEthernet1/16
switchport trunk allowed vlan 195,202
interface GigabitEthernet1/17
interface GigabitEthernet1/18
interface GigabitEthernet1/19
interface GigabitEthernet1/20
switchport access vlan 199
switchport mode access
spanning-tree portfast
interface GigabitEthernet1/21
interface GigabitEthernet1/22
interface GigabitEthernet1/23
interface GigabitEthernet1/24
interface GigabitEthernet1/25
interface GigabitEthernet1/26
switchport trunk allowed vlan 1,199
interface GigabitEthernet1/27
interface GigabitEthernet1/28
interface GigabitEthernet1/37
switchport trunk allowed vlan 199
interface Vlan1
no ip address
interface Vlan195
ip address 190.191.195.1 255.255.255.252
interface Vlan202
ip address 190.191.202.2 255.255.255.0
no ip http server
no ip http secure-server
ip forward-protocol nd
vstack
line con 0
exec-timeout 5 0
password 7 0518160301554B1B1606181C
logging synchronous
login local
stopbits 1
line vty 0 4
exec-timeout 5 0
password 7 03174B072616245E411F0D1C
login
end
Sw2:
spanning-tree mode pvst
vlan internal allocation policy ascending
track 1 ip sla 10 reachability
interface GigabitEthernet3/0/1
interface GigabitEthernet3/0/2
interface GigabitEthernet3/0/3
interface GigabitEthernet3/0/4
interface GigabitEthernet3/0/5
interface GigabitEthernet3/0/12
interface GigabitEthernet3/0/13
no switchport
ip address 190.191.240.2 255.255.255.252
interface GigabitEthernet3/0/14
interface GigabitEthernet3/0/15
interface Vlan199
ip address 190.191.199.10 255.255.255.0
ip http server
ip route 0.0.0.0 0.0.0.0 190.191.192.101
ip route 190.191.199.0 255.255.255.0 190.191.240.1
Router:
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 190.191.240.1 255.255.255.252
ip nat inside
ip virtual-reassembly in
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
I appreciate you help very much.
Leo Laohoo
Post the complete output to the command "sh interface <PORT>".
