Urgent query for Aggregate-Policer on c7600
zhiyyao
I would like to add 129.20.199.0/24 and 130.20.199.0/24 to the policer in the aggregate-policer ap-lala-d on c7600 that i have set now.
After consulting the documentation, I found the following three solutions. Please help me to see if it is feasible and are there any concerns?
■ Current settings
ip access-list extended smart-lala-src
permit ip 58.191.129.0 0.0.0.255 any
class-map match-any cmap-smart-lala-10g-d
match access-group name smart-lala-src
mls qos aggregate-policer ap-lala-d 134224000 16778000 16778000
conform-action transmit exceed-action drop
mls qos aggregate-policer ap-d 2550136000 31250000 31250000
policy-map smartphone-vlan-d
class cmap-smart-lala-10g-d
police aggregate ap-lala-d
class class-default
police aggregate ap-d
interface Vlan100
service-policy input smartphone-vlan-d
■ Setting plan
1. Add to class-map
⇒ There was a description that the previous one was overwritten by the last match command.
If the contents are not duplicated, will it work as expected?
ip access-list extended mgmt-dst
permit ip any 129.20.199.0 0.0.0.255
permit ip any 130.20.199.0 0.0.0.255
match access-group name mgmt-dst
2. Add to policy-map
⇒ Will the policy move in order from the top of the policy-map, and will the bandwidth of police aggregate ap-lala-d be consumed in order from the top?
class-map match-any cmap-mgmt-10g-d
class cmap-mgmt-10g-d
class class-default
3.Add to ACL
⇒ Is the following acl feasible?
Hope to get your support.
Best regards,
Zhiyang
2 would work, too, it will be processed top down, as you said.
#3 is the fastest and easiest way to accomplish this. Just add the two new networks to the existing access list. By doing that, you don't need to change anything else.
Thank you, my friend.
So the best way here should the plan 3, right?
And about plan 2, do you know about this question?
=>Will the policy move in order from the top of the policy-map, and will the bandwidth of police aggregate ap-lala-d be consumed in order from the top?
Zhiyang
