USB device not detected for ESS 3300
swa64211
Hi guys,
I trying to use USB device for ESS 3300 switch but the switch is not supporting commands related to USB.
Commands like show platform usb staus , platform usb disable are not being recognized by the switch. It'll be really helpful if anyone can help me.
I have attached the log for reference, thank you
log -
Switch#sh platform
Switch Ports Model Serial No. MAC address Hw Ver. Sw Ver.
1 26 ESS-3300-CON FJZ224804S0 70ea.1a6e.ace0 V01 16.9.1d
Switch#
sh platform
Switch#
Switch#sh platform
Switch#
Switch#
*Jun 25 21:07:36.538: %LINK-3-UPDOWN: Interface GigabitEthernet1/3, changed state to up
*Jun 25 21:07:37.538: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/3, changed state to up
Switch#plat
Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#pla
Switch(config)#platform ?
atm-cdvt Configure platform atm cdvt
bridge-security Layer 4 Sanity Check Filters
cfm Configure Multi-NNI CFM feature
cft Configure platform cft
console Direct IOS output to console
icmp Configure platform icmp
ip-ports Configure Kernel IP ephemeral ports
ipsec Platform specific ipsec command
l2vpn Configure platform l2vpn global configuration
macsec Platform specific macsec command
power Platform power command
punt-keepalive punt-keepalive messages
reload Platform specific reload command
shell Control platform shell access command availability
Switch(config)#platform us
Switch(config)#no platform u?
% Unrecognized command
Switch(config)#^Z
Switch#s
*Jun 25 21:08:19.520: %SYS-5-CONFIG_I: Configured from console by consoleh plate?
Switch#sh plat?
platform
Switch#sh plat
Switch#sh platform ?
atm-cdvt Display platform atm cdvt value
authentication Show switch auth info
bridge-security Platform bridge security
conditions Show conditional debug info
diag Diagnostic information
hardware Show platform hardware information
integrity Boot integrity
ip platform ip specific show commands
ipv6 platform ipv6 specific show commands
monitor platform monitor info
pm Show Platform Port Manager Info
power Power information
resources Show platform resources information
software Show platform software information
status Show Platform Status Info
sudi Secure identity
| Output modifiers
<cr> <cr>
Switch#sh platform us
Switch#sh platform usb staus
% Invalid input detected at '^' marker.
Switch#sh platform usb status
Switch#
Switch#dir ?
/all List all files
/recursive List files recursively
all-filesystems List files on all filesystems
cns: Directory or file name
crashinfo: Directory or file name
flash: Directory or file name
null: Directory or file name
nvram: Directory or file name
system: Directory or file name
tar: Directory or file name
tmpsys: Directory or file name
webui: Directory or file name
xmodem: Directory or file name
ymodem: Directory or file name
| Output modifiers
<cr> <cr>
Switch#dir usbflash0:/
%Error opening flash:/usbflash0 (No such file or directory)
Switch#conf t
Switch(config)#pla
Switch#sh version
Cisco IOS Software [Fuji], IOS-XE ESS3x00 Switch Software (ESS3x00-UNIVERSALK9-M), Version 16.9.1d, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Sat 13-Oct-18 02:22 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: Version 1.1.1 [RELEASE SOFTWARE] crashkernel=64M
Switch uptime is 3 minutes
Uptime for this control processor is 4 minutes
System image file is "flash:ess3x00-universalk9.16.09.01d.SPA.bin"
Last reload reason: power-on
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-essentials None network-essentials
cisco ESS-3300-CON (ARM) processor (revision V01) with 911604K/6147K bytes of memory.
Processor board ID FJZ224804S0
1 Virtual Ethernet interface
24 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3971156K bytes of physical memory.
523264K bytes of crashinfo at crashinfo:.
1684480K bytes of Flash at flash:.
0K bytes of WebUI ODM Files at webui:.
Base Ethernet MAC Address : 70:ea:1a:6e:ac:e0
Motherboard Assembly Number : 18C3F
Motherboard Serial Number : FJZ224804S0
Model Revision Number : V01
Motherboard Revision Number : 4
Model Number : ESS-3300-CON
System Serial Number : FJZ224804S0
Backplane FPGA version : 41
CIP Serial Number : 0xFF000000
SKU Brand Name : Cisco
Configuration register is 0x102
0 Replies 0
