Use extended ACL to access and deny TCP and ICMP
Hello!
I need to ping left side switches from right side switches ,and need to deny TCP from right side Switches to left side Switches.
I attached the  diagram.
Thanks.
"when I use "deny tcp any any" then both sides cant 'telnet'. do I need put all pairs of sources and destinations?"
Correct, which I why I mentioned (totally) blocking TCP in one direction will also (totally) block TCP from working, and so, my ACL did just that.
"I need to 'telnet' from left switches to right and I don't need to 'telnet' right side to left side."
That quite a different requirement, from you OP, and more sensible too.
What Paul shows, is one way to do that, but not the only way.  You could further exclude all TCP but telnet, while still allowing it (telnet) in one direction.  Further, depending what devices you actually need telnet access too, you might use a reflex ACL or, if router has the feature set, FW rules.
As to where to place the ACL, again it depends on ACL, whether in or out, and interface.
From an "efficiency" standpoint, you want to block (drop) as soon as possible.
From a "configuration management" standpoint, you want to define the ACL in as few places as possible.  For the latter, your interfaces that connect the two core routers, would be the best location.  (Although I wrote interfaces, i.e. plural, you could just apply the ACL on just one of the core routers.)
BTW, for understanding ACLs, keep in mind, from the perspective of the interface you apply it to, and whether applied in or out (or both), what will be the packet's source and destination fields.
If you have other questions, please ask, but hopefully, you now better see how you often need to be very specific in your requirements.  My original response, I believe, addressed your OP while trying to clarify your requirements.
For another example of requirements, it's unclear whether you need/want to have this ACL restrict certain address blocks.
8 Replies 8
Joseph W. Doherty
"I need to ping left side switches from right side switches . . ."
Well, that's the default, unless you use an ACL to block.  So, unsure what you intend.  Did you only mean to only allow that?  If so, that would block everything else.
". . . deny TCP from right side Switches to left side Switches"
ip access-list extended blockTCP
deny tcp any any !blocks all TCP, but TCP wouldn't work even if you block only single direction, however you could do so, then you need to be careful with source vs. destination fields, ACL's in or out, and what interface(s) placed on
permit ip any any
Hello @Asiri Vishwajith
Use the acl i posted and test against it
Kind Regards
Paul
Hello @paul driver
I tested, but it also can't 'telnet' to right side. Im trying...
Thank you
Hello
you wont be able too
You stated to deny all tcp/icmp from left to right that's what the acl is denying, initiation of tcp/icmp echo connections from left to right, However it will allow right to left.
Kind Regards
Paul
Thank you
Hello
Apply this acl to each rtr on the left gig0/0 interface
ip access-list extended left-right
permit tcp 172.16.x.0 0.0.0.255 172.16.8.0 0.0.7.255 established
deny tcp 172.16.x.0 0.0.0.255 172.16.8.0 0.0.7.255
deny icmp 172.16.x.0 0.0.0.255 172.16.8.0 0.0.7.255 echo
permit ip any any
int gig0/0
ip access-group left-right in
Kind Regards
Paul
