Use normal trunk port or use channel for connection access switch
Good afternoon people,
I have a question,
What will be the best option, I have backbone 4705E2x,  2x 3750X core switch (stacked) and will attach around 35 access switches (2960) to it for some production area.
I want to connect them as channel so I have a uplink of 2GB, when I would make just a trunk on both GB ports, SPT will automatically block one and I will have a uplink of only 1 GB.
What is the best option ?
See PDF file for drawing
Thanks guys!
I think, you already knew the answer while writing your question? ;-)
Yes, use a channel! Why wasting half of your uplink-bandwidth when you don't have to. Ok, also without a channel you could utilize both links with different spanning-tree costs for different links. But a channel should be better in every way.
michael o'nan
Level 4
Level 4
If you are going to do two links I would put them in an etherchannel. You will have bandwidth and failover capabilities.
Thanks Karsten,
Well i was a little in doubt and needed some confirmation to be shore.
That's why i asked this question.
Thanks a lot....
Have a great day
In your picture it seems that both 4k are only connected to one core-switch each. Make sure that you connect one channel-link to the first stack-member and the other channel-link to the other stack-member. With that you also have redundancy in case of a failing stack-member.
