Use of access-class 20 in vrf-also
mahesh18
Level 6
Level 6
Hi Everyone,
Need to  know the reason of command
access-class 20 in vrf-also  under  line vty 0 4.
line vty 0 4
I checked current device it has  no VRF  config.
Only  config i found is  on 4500 is
ip vrf mgmtVrf
interface FastEthernet1
ip vrf forwarding mgmtVrf
But this Management interface Fa1  is shutdown.
Do we need access-class 20 in vrf-also under this setup?
Mahesh
Reza Sharifi
Hi Mahesh,
That access list is there so you can limit access coming from a specific vrf.  In this case it is the management vrf.  If interface fa1 is shut, there is no vrf and everything is in global routing table, then you don't need that access list.
Reza
Reza Sharifi
Hi Mahesh,
Reza
Hi Reza,
Many thanks again for confirming my thoughts.
Best regards
MAhesh
