username problem
Aquil2012
i have below model switch
i have configured it
username <username> privilege 15 password <password>.
but it don't show username it is asking for password only
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960S-48TD-L   12.2(53)SE2           C2960S-UNIVERSALK9-M
John Blakley
On a telnet connection? When you configure the username, you'll need to also change the line to support that authentication:
line vty 0 4
login local
We recommend using a radius/tacacs server if possible, but you can also use aaa authentication without a tacacs/radius server like:
aaa new-model
aaa authentication login default local
line vty 0 4
login authentication default
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Hi John,
with aaa the default authentication method is automatically applied to the vty lines so no need to to configure it unless you want to apply another method specifically to a vty line.
Alain
