Using ACL to block access to other internal networks
pointless_l
I have a Cisco 1900 router configured with 3 subinterfaces. I want one subinterface to only access the internet and not the other 2 interfaces. When I use access-group 130 in on the interface my users don't even get a DHCP lease, when I use access-group 130 out my clients can't reach any network. Any ideas on when I'm overlooking?
interface GigabitEthernet0/0.3
encapsulation dot1Q 240
ip address 192.168.240.1 255.255.255.0
ip access-group 130 in
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
no cdp enable
access-list 130 deny   ip any 192.168.20.0 0.0.0.255
access-list 130 deny   ip any 192.168.33.0 0.0.0.255
access-list 130 permit ip 192.168.240.0 0.0.0.255 any
Any help is much appreciated.
gatlin007
Level 4
Level 4
Apply this inbound as you have in the example.  Add the following to account for a DHCP request.  Remember the client doesn't have an IP address when it sends a DHCP request, so it won't match the 192.168.240.0/24 permit any line.
access-list 130 permit udp any any eq 67
If your DHCP server is in 192.168.20.0/24 or 192.168.33.0/24 then this line must occur at the beginning of the ACL.
Chris
gatlin007
Level 4
Level 4
Chris
Thanks Chris, that worked flawlessly!
Yudong Wu
Level 7
Level 7
You should use "access-group 130 in" based on your description.
Where is your dhcp server? You can change acl 130 as following and then check the log to see what is denied for DHCP. Then enable it accordingly.
access-list 130 deny any any log
