Using SVI Vlan with no ip address
mahesh18
Level 6
Level 6
       Hi Everyone,
When we will use SVI vlan  in network with  no ip address command?
Say we have switch with
int vlan 50
no ip address
Ports are configured  for vlan 50.
This current switch has no ip address for vlan 50.
So does it mean that some other switch  in network has to have  IP address command configured for that vlan 50?
Mahesh
3 Accepted Solutions
Reza Sharifi
Hi Mahesh,
If that that vlan doesn't need to talk to another vlan, then you don't need SVI anywhere.
The vlan will communicate with itself only.
juanvladimir
i agreed with Resna. No intervlan routing needed no need for SVI layer-3 address.
Hi Mahesh,
so does the config of ASA  shows that it has SVI vlan of 50?
Correct, in this case the switch is just layer-2 and the ASA is doing the routing.  In this case this is just the physical interface and not SVI.  SVI is used mostly for switches.
Please note: this works fine when you only have one vlan.  If you have more then one vlan then you need to trunk the link that connect the switch to the firewall and create a sub-interfaces on the firewall for each vlan/subnet.
Reza
7 Replies 7
Reza Sharifi
Hi Mahesh,
juanvladimir
Hi Reza & Juan,
Say we have ASA  interface  which is assigned to vlan 50--- config
int gi0/0
nameif x
vlan 50
192.168.50.x
We have switch A  which has config---
int vlan 50
no ip address
Mahesh
So you only one one single VLAN i.e VLAN 50? Can you elaborate what exactly are you trying to accomplish here?
Hi Mohammad,
I was just trying to undertsand the setup here.
Where ASA has interface configured with IP address and vlan 50 and is connected to switch which has svi vlan 50 but no
ip address.
Mahesh
Hi Mahesh,
Reza
Hi Reza,
Many thanks again.
Mahesh
