Using the same local VLAN in Remote locations with different VTP domains
douglas.mckee
Can you use the same local VLAN in multiple remote areas which have different VTP domains? When specific users log on from remote locations we would like them to be assigned to a local VLAN from our main location. Is this possible or will this just cause more issues?
Thank you,
Doug
17 Replies 17
We have about 15 remote sites to connect but will look at LISP along with the L2TPv3 option as well. Never worked with either so will go with the easiest solution after doing some testing.
Thank You,
Doug
Forget L2TPv3.  It wont scale to 15 sites very easily.  It will be difficult.
Either for for LISP, or get a price from your service provide for a layer 2 WAN service.
LISP would suit this problem very well I must say, and all your current routers have LISP functionality.
I'll also mention it again, if you could limit this application to WiFi only this is much easier to solve using the your Cisco WLC.  You would just need to fix your WiFi network.
Jon,
Correct. This is the requirement we need to meet.
Thank You,
Doug
